Hi,
I just got a new monitor, a Samsung T260HD for use with my new macbook, I was very enthusiastic about it just to find deception with the new macbook.
Starting with the fact that I needed to get a mini DP (i hate those mini propietary versions and the fact that i need to pay 30 more, anyways) I plugged in everything, and when i maxed out my monitor to 1920x1200 there is noise in the image on the monitor, and by noise i mean.
1. Random Green lines accross the screen, sometimes they do, sometimes they dont.
2. And VERY annoying, noise on images, like some pixels start to turn white and it looks like the image would be shinning. I knew this was bad since the monitor in its TV function doesnt show such behaviour.
I thought the TV was defective, but then I plugged in my old 12" Powerbook with its mini dvi cable to the TV and it was capable of handling the exact resolution with no noise at all! The picture was perfect, and the white dots were not present.
I rechecked, and my macbook did good.. at first, when i tried again with a movie from apple trailers in 1080p and the results were disastrous... noise started to appear when the movie started to play. And I should add that this white dots are easy to notice on black/dark spots... so it is very annoying.
I asked my roommate to try with this macbook pro, (non DP one, like 1 year old model with direct DVI, no mini junk) and it worked flawless on his.... I tried mine, with a DVD and same result, noise noise noise that apparently once it is triggered it doesnt stop being so.....
So my roommate gave another shot and his computer displayed nicely the DVD on the external monitor. I concluded that the monitor is FINE, but that the issue is with my new Macbook and its graphics card I guess...
The problem is present when the resolution is high like 1920x1200 and if i lower to 1360x something else, it has no noise at all... I gave a shot in windows to get the same problem. High resolution = noise in the new macbook.
Im highly dissapointed, and tomorrow im gonna try this out in the apple store and try to get support, but I was wondering if anyone has similar issues?
I dont know waht to blame, the mini DP to DVI adapter is brand new, im using the monitors DVI cable which works fine in 2 computers.
I wonder if this is an issue of the converter or my graphics card is faulty ******.....
Anyone has a similar problem here? Or can provide with some ideas?
Thanks in advance,
Manuel
Thanks in advance,
Manuel
