Well, 10.9.2 was seeded to developers before Xmas, let's hope it's fixed this time...
I am about to find out. Pulling that beta as I write this.
How has 10.9.2 been? Is the issue fixed based on your usage?
Since I installed it earlier, I haven't had too much time to really attempt to induce a failure, but so far, so good. Not once has it happened. Give me until tomorrow to really get a definitive answer though.
OK guys, I have had enough time to really play with this, and I can say that I am confident that this issue is fixed in 10.9.2.
I highly recommend that you guys just go ahead and update to the beta below. Its a bad enough bug that it had REALLY ruined my enjoyment of my new Air, and this is probably the only time you will hear me advocate beta software to an end userbase. If you are tired of this crap, heres the link:
http://www.techglobex.net/2013/12/download-os-x-mavericks-1092-beta-dmg.html
is it safe to install 10.9.2 even if not a developer? I always see warnings against it so just want to be sure..and also do you need some kind of access code once you install it like the UDID business on iOS Beta software updates?
Also, I've heard the FaceTime camera does not work in 10.9.2, can you confirm?
sounds good!
One question: did you once just for the sake of it send your mac to sleep (for a longer time, as in dee sleep) with the headphones still connected? That's when the kernel malfunctions most of the time for me. Or what sort of tests did you do that you are so confident that this has been fixed?
Thanks for keeping is up to date!
Just wondering if anyone else has tried out 10.9.2?
I'm too afraid of bricking my machine 😀 first mac and all...
I have downloaded 10.9.2 overnight and expected it to self install, but it has saved as a .dmg file.
However I can not find the method of now installing it over 10.9.1 as I would normally with a download.
tut
I added 10.9.2 and it fixed the issue on my 2013 MBA 13 i7 8GB 256Gb. I'm getting much better battery life now. Thanks.
The problem's getting worse for me. Currently averaging about 5 hours battery life on a 2013 with i5.
I only use Safari, don't have flash installed, and Activity monitor isn't showing anything taking up a particularly large % of CPU activity.
Anyone else stuck on "Collecting Power Usage Information" that never resolves?
