MacRumors
macrumors bot
70,474
42,179
Bang & Olufsen today announced Beoplay EQ, the Danish audio outfit's first true wireless headphones with adaptive active noise cancelation.
To achieve maximum noise cancelation, the buds use adaptive ANC that combines active noise cancellation with passive sealing. Six microphones allow for automatic adjustment of ANC levels and also make use of directional beamforming technology to improve call and speech quality.
The Beoplay EQ will retail for $399 (£349/€399), so they're $150 more expensive than Apple's AirPods Pro, but apart from the premium look, they do pack some solid features, including 20 hours' battery life when used in conjunction with the charging case, and 6.5 hours of playtime with ANC turned on (versus AirPods Pro's 4.5 hours). They also include a fast charge feature, so 20 minutes in the aluminum case gets you two hours of playtime.
The compact case supports both USB-C and Qi wireless charging, while the buds themselves are more reminiscent of Beats Studio Buds than AirPods, with a small profile and an ergonomic fit. They're IP54 dust and water resistant, and come with interchangeable ear tips in different sizes.
Wireless specs-wise, they support the aptX adaptive codec and the latest Bluetooth 5.2, and the set-up process is simplified on both Android and Apple devices thanks to the inclusion of Microsoft Swift Pair and Made for iPhone licenses.
Beoplay EQ come in Black Anthracite and Sand colors and will be available to purchase from August 19 via Bang & Olufsen's website and in Bang & Olufsen retail stores.
Article Link: Bang & Olufsen Announces First Noise-Canceling True Wireless Earbuds
I'd definitely be interested in buying these. I have the H95's and they are spectacular and wonder how well these would perform.
it will probably be good. However I think that the recently covered Nothing Ear 1 will make a much bigger impact in the market, keenly priced at only $99/set.
Reactions: SantaFeNM
“20 hours' battery life when used in conjunction with the charging case”
So if you leave them in the case they last 20 hours? What does this mean? There was another article about some other brand recently that made the same kind of statement.
This simply means 6.5hrs for the buds and additional 13.5hrs for charging case. So 20hrs in total.
Reactions: DeepIn2U
What’s better, adaptive noise cancellation or active noise cancellation? I thought active was, but this article’s wording seemed to point in the opposite direction.
