ProwlingTiger
macrumors 65816
So I've had the Retina Macbook since launch and continuously achieved near 10 hours on a full charge. Now I'm getting 3.5-4 hours. I've applied every update and I'm running the latest public build of El Capitan. I've attached screenshots from my activity monitor. The battery indicator blames Safari. I have one window open with 5 tabs and Safari isn't a problem according to Activity Monitor. I've had 5 windows with 40 tabs open before and still got great battery life.
What should I do?
Did you check your battery health stats using system report in about this mac? If your full charge capacity has taken a dive then maybe you've got a dodgy battery in which case, warranty repair time.
flash content?
I don't have flash installed.
System report says everything is normal:
Battery Information:
Model Information:
Serial Number: D86506401LHFQM68L
Manufacturer: SMP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 702
Hardware Revision: 500
Cell Revision: 3202
Charge Information:
Charge Remaining (mAh): 4866
Fully Charged: Yes
Charging: No
Full Charge Capacity (mAh): 4866
Health Information:
Cycle Count: 79
Condition: Normal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 8664
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
AutoPowerOff Delay: 14400
AutoPowerOff Enabled: 1
Current Power Source: Yes
DarkWakeBackgroundTasks: 1
Display Sleep Uses Dim: Yes
GPUSwitch: 2
Hibernate Mode: 3
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 10800
Standby Enabled: 1
Battery Power:
System Sleep Timer (Minutes): 5
Display Sleep Timer (Minutes): 5
DarkWakeBackgroundTasks: 0
GPUSwitch: 2
Hibernate Mode: 3
Reduce Brightness: Yes
Standby Enabled: 1
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 29
Serial Number: C4H511703JAFPWWAN
Name: 29W USB-C Power Adapter
Manufacturer: Apple, Inc
Hardware Version: 1.0
Firmware Version: 3060002
Charging: No​
I'd call Apple, of all the Apple laptops (MB, MBA, MBP) I've had, they have been very consistent in the way the battery performs. I think it's one area that Apple understands well and has properly engineered.
Thanks, I'll call them. Just haven't had the bloody time recently.
