Changing GUI of parts of Leopard
Discussion in 'macOS' started by munson, Mar 31, 2008.
  1. munson macrumors 6502
    munson
    Mar 23, 2008
    Boston, MA
    #1
    So, I was wondering if anyone knows who to alter these things? I was looking to change the Bar at the top of Leopard, you know, the one with the Apple symbol and all that jazz (I still don't know what it's called). I have already found an app to change the dock.
    Also, tips on how to customize other parts of my GUI would be appreciated.
  2. rmh macrumors regular
    Sep 12, 2007
    Texas
    #2
    Are you referring to the Menu bar? The only changes you can make to it are changing it from transparent to gray in the "Change Desktop Background" prefpane. I don't believe there is any way to customize it beyond that.
  3. munson thread starter macrumors 6502
    munson
    Mar 23, 2008
    Boston, MA
    #3
    Well, I'm not too sure, but I have seen it. I'm pretty sure there is a program that can do it, It's called ShapreShifter, but the website says it does not work for 10.5 :( (check out www.interfacelift.com to see what I'm talking about.
    Does anyone else know of a program that does this?
  4. rmh macrumors regular
    Sep 12, 2007
    Texas
    #4
    Ah, I forgot about ShapeShifter. It seems like they are working on the Leopard version, so your best bet might just be to wait it out.
Share This Page
