spaceballl
macrumors 68030
2,941
365
San Francisco, CA
My fans make a slight bit of noise... like they're flapping against a part, a fast-ish clicking noise. It's faint, but when working in silence, quite annoying. I think this is a flaw and i'll have to send it back... Curious if anyone else has bumped into this issue.
My model is a CTO 15" 4GB / 15" HR glossy / 512GB SSD MBP.
Unless I change the smcFanControl to "Higher RPM" I can't hear a thing except the occasional click of the HDD or cd drive.
I think with the 2010 MBP's with high spec's make a bit of fan noise when doing normal tasks.
Perhaps because running in discrete graphics most of the time?
Definitely more noticeable that my '09 2.8ghz C2D 15" MBP ... not a 'click-ish' noise more so a whisp/hum as you say not loud but in a silent room you notice it.
When/if Apple releases a way to control integrated or discrete mode then I think the posts about fan noise or heat will die down.
My computer doesn't make a sound. Maybe it's the SSD, but I never notice the fans and temps are always in normal range.
Yeah that's what I figured - I'll have to send this sucker in! Annoooooooying. Oh well. I guess that's what warranties are for.
No - the noise is not the high-rpm noise associated with high CPU / GPU temperatures. It's a faint clicking noise that is noticeable at default fan speeds of just under 2k rpm.
