nconnella
So I found a solution to the unimpressive battery time I've been recieving on my mid March MBP. I like many others was getting half the time I should be. It turns out after doing a fresh install WITHOUT migrating my data, I now get better battery performance. So something with migrating my preferences/files is causing the problem probably because I was migrating from a machine with different hardware ('08 unibody)so the preferences were conflicting or something... I'm no expert. So my question is, Apple told me to copy my data over without doing a data migration so I am wondering what is the best way to do this? How can I make sure all my data copies over? I'm scared I'll miss something by just dragging things over from Time Machine, and some programs don't seem to work when I do that. Does anyone have tips on the safest, easiest way to do this?
Safest and easiest way would be to use Migration Assistant, unless you want to manually transfer over your files and reinstall your programs.
I'm affraid that's what's causing the problem. Something is being copied over in migration assistant that is causing the reduced battery life. Is there a difference between data migration and migration assistant?
I would also like to know because I am in the same situation as the OP. What would be the best way to get my stuff on the new mbp with out hindering my battery life?
