VideoBeagle
823
18
App Q&A testing by request.
I'm trying to track down a sound problem.
I'm finding in some recent Handbrake rips, some ...pops? hard to describe..every couple of moments there's a drop or a blank or a glitch (best I can think of) in the audio.
(described as blanks by 2 friends I sent the below sample to)
I found this checking the encodes on Beamer -> Apple TV -> Sony Receiver -> TV. I checked the file with VLC on the iMac, and they're there, so it's none of the set up beyond the file. I checked the original file I converted with Handbrake, so it's somewhere between Handbrake's conversion and the mac playback.
I'm using the Apple TV 3 preset.
I've seen it in several different files.
At least the sample file below has been played on 2 different macs and a Windows 7 desktop.
There's 2 pops in this audio clip. It's the 20th Century Fox fanfare, so you should hear them easily at about the 9-10 second mark and the 16-17 second mark.
https://www.dropbox.com/s/d2tyktbd0ohfgv8/sound.m4a
or
https://dl.dropbox.com/s/d2tyktbd0ohfgv8/sound.m4a?dl=0
(I used Quicktime to trim the big file, then exported to audio only to make the clip)
these are the settings...
(Subler used for the top 2 pictures)
Can anyone suggest what's going on? This seems to be a new issue I'm running into.
(Handbrake Version 0.9.9 x86_64 (2013051800))
Ok, this file done in the same batch as the sampled one above doesn't seem to have the pop/blank problem..
The clear difference being the sound track of the original files, which despite playing with no issues in VLC, are converted differently by Handbrake.
