Apple...
macrumors 68020
2,148
The United States
Hey, guys. I upgraded my Mac Pro this afternoon, adding 6 more GBs of RAM and another hard drive in the second bay area. The computer recognizes the total 8GB of RAM (I upgraded from 2GB), but the amount of hard drive space I have is still the same? My main drive (the one that originally came with the Mac) is 250GB, and the one I added in addition to my main drive is 1TB. How do I get the system to recognize the added space? I'm new to this, and I'm pretty sure I installed it right, but I'm having trouble getting it to work. Any ideas? I've looked through Disk Utility, but all I got was a headache... :(
Thanks.
I'm guessing the drive is formatted but unallocated. You have to use disk utility to allocate a partition on the new drive.
The hard drive space will not add onto the current 250GB like RAM does. Each disk is indipendent and do not relate to each other at all (unless you raid them). The new 1TB drive should be mounted to the desktop as a seperate disk, once formatted. It will show up like a USB drive or CD. Files can be copied to it, saved to it. ect, but will not be included into the "Macintosh HD" space. If you want to use that drive as your main drive, you can use apples migration utility to copy your computer to the new drive. But then youll have the 1TB as the primary drive and the 250GB as the other drive.
