Brilopad1
19
Landenberg, PA
Alright, here's the situation. Last week I shut down my computer to go away for thanksgiving, and when I came back and turned on my 20" white intel imac my hard drive fan sounds like it is going max rpm. I have istat pro installed and the rpm for the HDD fan is showing it's at zero. Does anybody have a clue as to why this is happening? My computer was working fine when I last used it but now my fan is going crazy. It's really loud and i'm concerned my the life of my fan. Any suggestions on what to do would be great.
I installed Snow Leopard after the problem occured, but it's still happening.
I recently had this happen after a new HDD install, fans were going 3000-5000 on iStat. Turns out something was wrong with a sensor (can happen on a new install), had to take it back in and the Apple store took care of it.
What do you think would cause it to happen since I didn't download or install anything before the fan speed started going crazy. And do you have any idea why my fan rpm speed is showing 0? I'd really prefer not to have to take it to an apple store since the closest one is 3 hours away. Just curious, but how much did it cost to get fixed?
Doesn't matter. If the fan is reporting as 0 RPM, it's a hardware (or maybe firmware) problem and not something that any application could affect.
I don't know why it was showing 0. My problem was totally related to the HD install, if you didn't have anything replaced or changed hardware wise yours may be something different. As for my repair, it was all done under Applecare, so I don't know the cost of a repair.
Does anyone know how to fix this yourself?
I bought my iMac 2 years ago in may, and it has been happening since I bought it. I've taken it to the apple store 5 times, and every time they "failed to replicate the problem".
but I'm sitting right now at 30°C and the CPU fan running at 4600-RPM.
I'm contemplating just opening it up and unplugging that fan. (bad idea I know.... not really sure what a good idea is).
any tips?
