Ok, so my IMac will not turn on (it is a 20" IMac, G5 btw) and after reading some of the thread on here and other forums, it appears it may be the little battery in need of replacing, as this is the 3RD TIME this has happened. The previous two times the IMac just came on by itself after about 24-36 hours.
So for the first time I open up the back and I see the little battery. Seeing a metal clip holding it down, I pull up on the clip to get the battery out so I can get it replaced. But I notice the Clip now has NO TENSION at all and when I try and see if the battery will go back in and be held down, it won't!
Did I break the clip or make it useless by pulling back on it? I tried everything I can think of to get it tight, using needle nose pliers, etc to try and reshape it but not working still!!!
I don't want to take it to the apple store because I am sure they will make me pay of the wazoo and I'll get and earful for trying to fix it myself, although it is out of warrenty
. Does anyone know of a good alternate Apple repair place in Jacksonville Florida area IF that is what I need to do?
Thank you for your help in advance and any help would be appreciated!
Brad
Brad
