Hi All, looking to connect my iPad Pro to an external monitor but not having much sucess (even through apple support) so wondering if I am missing anything? I have a 1080p HDMI monitor which works with my Mac mini, I have an apple Multiport adapter for my iPad so thought I could use the HDMI port to connect the monitor (and mirror the screen). But it won’t work. I’ve not found any details around what specifications the monitor or cable needs to be as I wonder if there was a minimum and my monitor is too old or the cable is wrong?
I have tried restarting, reconnecting, new cables, software update etc but the monitor doesn’t get a signal. Any ideas? I just got this monitor as my previous one was only a vga and I thought it would be great. (I replaced my old MacBook Pro with an iPad Pro, and just getting used to the different way of working but the monitor would help me to view split screen a bit bigger as i get used to running less documents at a time). If it all worked I was contemplating trying shiftscreen maybe, if the monitor had worked.
Thanks heaps
*M
Thanks heaps
*M
