So , I have saved and saved and now it is time to buy the hardware
Basically , I will be buying either a Macbook or MBP(Apple refurb) very soon along with some external storage, a MIDI controller and maybe a sound card too, probably just after WWDC , I would love to get some advice on on it all.
I've been looking at this http://www.g-technology.com/Products/G-SAFE.cfm & http://www.g-technology.com/Products/G-DRIVE.cfm for back up .
I'm thinking about getting a faster drive as scratch disk for every day use but to be honest I don't really know what to choose or if I would need it ,do I go in using the PCI slot on the MBP and FW800 drives or what
, I don't really know what to choose , I suppose it depends if I go MBP or not.
I like the look of the G Tech back up hardware at http://www.g-technology.com/
and think I will buy stuff from there it is kind of sexy looking and there stuff gets reasonably good reviews .
I'm also trying to decide if i need to buy a sound card and MIDI controller or not which, hope fully , is where you come in.
I mix vinyl on Technics at times & record to digital ( need to record in pristine audio) .
I make electronic music & remix's ( well try too) using software instruments in Logic Express 7 (soon to upgrade to LS) & GB ,I use no external 'real' instruments, I'm waiting on new purchase(s) to start on the learning curve that is Reason , I've dabbled for a while and would like to start to get more serious about quality of sound and production ....
Sorry about the long ,rambling & possibly incoherent post
...I have been reading all over the forum for weeks now and suppose I'm really just looking to bounce some ideas around with some like minds and chat about buying options
I need some advice , I have about £1200(ish) UK £ as budget limit
Help me spend it
thanks
Help me spend it
thanks
