milesdavis100
5
Hello,
I had a battery replaced in my MBA …
When I picked it up and tested it - the computer would turn on, then shut off..
Apparently, they didn't test it very well or forgot to
According to the genius folk - my computer had some corruption between the file system and the hard drive [ they said it was not a hardware problem , but would likely need to erase my disk and reinstall ]
The HD is VERY full - so disk utility could not be run
She suggested I take it home and run Disk Warrior or something similar…however, that is just not possible with an external drive [ as far as I could figure out ]
I managed to make a disk image from disk utility to an external drive in recovery mode….
I then attempted to BOOT from that drive -- I got the endless grey screen :(
NOW I can't turn off the power!! I hold down the power button and it won't go off. This happened to the rep too in a different similar screen at the store -- however, turning it off works fine and worked fine in recovery mode …
I held down power for about 5 minutes at least to be sure and it doesn't help
So now -- I'm trying to let the battery run out -- but I am super confused. What did they do to it?!?!
Thank you for any help / thoughts -- MD
Hello,
According to the genius folk - my computer had some corruption between the file system and the hard drive [ they said it was not a hardware problem , but would likely need to erase my disk and reinstall ] ...
If your computer worked before and doesn't work now, and the only thing that happened is that Apple did some work on it, I would demand that they return it to the state it was in before you gave it to them. Ask to see a manager, etc.
Replacing the battery does not affect your hard drive, file system, etc.
