diamondarmada
Hey guys, I've had an iPad since August, and it's worked perfectly up until now!
Every time I try to play a song or play a game or... heck even do anything involving sound, the function keeps changing to "Dock Connector" back to the regular volume controls after 2 minutes, then goes back to "Dock Connector" and i don't even HAVE one plugged in! It just keeps changing over and over again. I don't know if it's an OS fault or the actual hardware is screwed, but I'm really frustrated!
it cost me £600 for this thing and I don't want anything wrong with it... is there anyway you guys could solve my problem?
Thanks o0 Will Ryan 0o
I wouldn't have thought so, but I shall check. I've done quite a few things actually, I checked to see if the dock connection port is a bit fault and everything seems fine there, the headphone jack is the same there's no problem there, all I seem to find wrong with this ipad is the softwrare. I'd be surprised if there was actually something wrong on the inside but I can't see anything :/
