mgartner0622
macrumors 65816
1,018
Colorado, USA
I thought I'd ask for some help for this issue that's been puzzling me for a few days. I have a friend's 13" Mid-2009 2.26GHz MacBook Pro he asked me to take a look it. It was loading very slowly and the hard drive was making clicking noises.
The first thing I told him was to buy a new hard drive and backup his data, which he did. The issue now is, even after installing a new hard drive, and reinstalling Mac OS X Lion on it, the loading slow issue still persists, basically 10+ minutes to boot. The hard drive works normally (30 second boot) in a USB SATA enclosure however.
I've tried cleaning the unit with compressed air to no avail. It also has a clean install of OS X with 8GB of RAM.
Any ideas?
Did you use Disk Utility to verify/repair the disk? You may also want to take it to Apple and let them run some hardware tests, to see if the problem may lie elsewhere.
Yes, the disc checks out with disc utility. I ran Apple hardware test and I can't get the computer to start up. It loans the main diagnostics then quits
