Okay, basically we got a new router yesterday, its an N300 wireless dual band adsl2+Modem Router, because our old 02 thomson wireless box stopped working for unknown reasons. I had already had issues with the old router, where it would disconnect randomly especially after it had gone to sleep. Now, my mac refuses to connect to the new router, the router works fine on our PC which is where it is based at, and works fine on my sisters laptop. The mac recognizes the network, as its name "NETGEAR-2.4-G" however it also recognizes "NETGEAR-DualBand-N" I don't know why this is, but on our router login, it says that "NETGEAR-2.4-G" is its "Name (11G SSID)" and "NETGEAR-DualBand-N" is its "Name (11N SSID)", thats he first problem. The other problem is that when i try to connect to either of these networks, i type in the WEP and it tries to connect then says "connection timeout" after trying for about 10 seconds, so i turned off all security settings temporarily, and it still won't connect, it either ignores that i pressed the network, or has the bars on the connection image going up and down
recently, it had full bars, though did not say it was connected to anything?? would be really grateful for any help, even if you have any suggestions in setting up an entirely new network just for my mac!! Thanks
