UDID isn't activated for iOS 7.I had to reset and now I can not activate iOS.Text:This iPhone is currently linked to an Apple ID (d*****@gmail.com). Sign in with the Apple ID that was used to set up this iPhone.But this is not my ID.
Going back to iOS6 doesn't remove the activation lock, AFAIK - I just did it on my iPad and wasn't able to activate in iTunes until I entered my password.
I would suggest emailing that person and explaining the situation.
It's his own email, why would it be someone else's? The feature isn't present in iOS 6 so you should be able to set up the device without an issue once it's restored.
The OP said "But this is not my ID," which I took to mean it was not his email address.![]()
Also, I just downgraded an iPad from iOS7b3 to 6.1.3 two days ago, and was unable to set it up until I had entered the correct AppleID + password due to the activation lock function having been activated while on iOS7. So no, downgrading to iOS6 does not remove the activation lock.
I just typed in my password and it worked fineWeird. So what did you do?
I suspect we're going to be seeing a lot of these threads in the months and years to come; I hate to assume the worst, but I'll bet that the vast majority of them will be due to theft (including people buying stolen iDevices off Craigslist or wherever) rather than simple user error ...![]()
Change pc,dfu mode,restore last oficial<?
I tested all PC,DFU mode,Restore to iOS 6.1.3 nothing helps.
Have you tried contacting the person to whom that AppleID belongs and seeing what they say? That would seem to be the next logical step if everything else has failed.
Hi,I see only d*****@gmail.com .I can't contact this person.
So this isn't your iPhone originally?Hi,I see only d*****@gmail.com .I can't contact this person.
I disabled activation lock now just to be sure that in case Apple messes up...
The iPhone is mine. The iOS7 that I installed did not have UDID account. It was downloaded from an online forum. Is there a way It can be activated the way it is with this registration?
If not can I register as a developer and get my own UDID account in order to activate the phone?
He doesn't "own" his iPhone any more.Adding your UDID to a developer account won't help you to bypass the security lockout. Your only option is to contact Apple; if they're unwilling to help you due to it being an unsupported version of iOS, you'll have to wait for iOS 7 to be publicly released before getting their help.
Wise. First thing I did when I installed iOS7b.So this isn't your iPhone originally?
