mattcube64
macrumors 65816
1,297
115
Missouri
Hi guys!
I have a 1st Gen Macbook (White). Anyways, a few months ago, the edge of the palmrest closest to me, where my right wrist lays, started to crack...
Then, several weeks ago, my clicker below my trackpad started making a very loud "CLICK" (lol... obviously) sound. It's actually a bit distracting when in the library or something. Also, it seems a little less responsive then it's supposed to be.
And now, the area below my left wrist is beginning to crack.
So, my first question is: If I take my computer to the Apple store (I do not have Applecare, just fyi), how much will they charge me to replace the palm rests?
AND: Is a new "clicker" part of a "palmrests package?" And would getting it replaced likely reduce the "clicking" problem?
Thanks!
If it is still under Applecare, there should be no problem replacing it for free.
If not, instead you should take it to an independent Apple Certified Tech near you and pay to have a new palmrest/trackpad put on BUT since they charge by the hour, you should also upgrade the hard drive at the same time.
I suggest this because they will charge you by the hour for taking apart the MacBook and you might as well throw some new hardware in there while the laptop is open.
I do have to say this trackpad problem sounds like a warranty issue.
Hope you have Applecare.
The OP stated they don't have AppleCare, and a 1st gen Macbook is older than 1 year. However, since this was a very known issue, I think they will still fix it for free. Your best bet is to call up Apple and ask.
Same here with the same MB.
I'm taking mines to the store soon.
A guy at work reported that yesterday he had apple replace a cracked palmrest, and it was 3 months after the warranty. I don't think it matters, but he was in Orlando, FL area. It only took a hour, about the same time as when I had it done.
