If I remember correctly, 2013 iMacs are the first ones that implemented PCI-E connection for SSDs which does make SSDs significantly faster than SATA counterpart. So if that is correct blade or not, you should be getting 6gbps therefore making either option abut the same speed in therms of maximum bandwidth.
