Does anyone have this? Just installed it. First edge to edge I have. The sides of the whole phone feel like the glass screen protector is like lifted up? Is this normal?
also do you know if ultra thin / thin cases will fit with this on??
who makes the best brand without the notch cut out? That is where my current screen protector cracked....so I am looking for a real edge to edge? is there such a thing? where the top actually rolls over the side of screen?
I’m using this screen protector (which is just like the one you’re using) along with this case. I haven’t had any issues with the edges lifting up and if there are any air bubbles present when I install it, they disappear within 24 hours.
