Bro, this can help.
Also, humming sound is not fan noise.
I definitely feel a gentle small airflow coming out from the speakers. It's definitely a fan noise or some sort of "white noise" sound
It’s likely white noise you can hear, a speaker isn’t turning off.
Have you tried restarting the phone?
Sadly if it’s still doing it, you’ll need to return it as faulty.
I noticed its because of an app i downloaded using test flight. each time this app opens after a few mins the white noise comes on!
You need to burn the speaker. It will disappear after a while if you put the volume at 100%. I can suggest you try with some Hardstyle, it will make the bass better after time.
You can try with the song “Big Bang” , from Noisecontrollers at full volume. It should not saturate the speakers.
.......is this really a thing?
The only fan noise is the roar of the crowd celebrating the launch of Apple’s iPhone 13, the most powerful iPhone ever. If you listen closely, however, you can hear the sound of FBI agents shuffling though your photos
  • Haha
Reactions: shr631
