Your palm hurt when using iPhone naked in long term?
  • Yes
  • No
Results are only viewable after voting.
amputpepet
Suspended
How to prevent my palm and nerve hurt in long term? I use it without case (I don’t like use it with case) Maybe i got sissy skin.
Reactions: haruhiko
This may just be an initial discomfort and may go away. If it doesn’t, consider either a case or train a different grip on the device maybe.
Reactions: Taz Mangus
It's not a matter of holding the iphone 13 Max wrong and if you are using a military grade Iphone 13 Max case with the sliding camera protector and the built-in ring stand, this type of case is obviously bigger than the iphone, which means the sharp edges are even worse. But I do see some cases, which do have rounded edges, however, these cases appear to not be as good as the military square (sharp) edged cases in terms of protection. I will never buy another square edged iphone again.
