Pro. If I had a Max, I’d have included that in my statement. 🙂Pro or Pro Max?
I have the same 17PM - I did hear it once - but only charging with MagSafe. Never happened with usbc cable only. Then again - I haven’t noticed it with MagSafe any more either….I am relieved to report that I do not have this issue. I have a Christmas Day 17 Pro Max 256GB in silver. I charge wirelessly on my night stand right next to my ear and I have excellent hearing. Perhaps it’s been addressed at the factory already, or it is not universal across the line. Let’s hope.
Correction: I DO in fact have this issue. After another user pointed out I needed to be charged above 80% and plugged into a wired charger, I tried again and if I put my ear right to the speaker I can hear it. It was very, very quiet and required conditions I will not normally meet. I’m sure Apple will sort it out. In the meantime, fortunately it will not impact me.
Sometimes, during the night, it sounds like it’s worshipping satan
This is something I have experienced with my 14 Plus. I found that turning off stereo recording fixed it....a constant hissing noise when turning on the camera...
The Air was a before/side effect for the real thing which will unFOLD this fall/autumn.“Thank goodness I have a less capable phone, so less can go wrong!”
That said…if the Air wasn’t useless for macro photography due to the lack of the ultra-wide camera and it had dual speakers…I might have gone for it instead of my 17 Pro.
Might.
It's been making the noise for me from day 1 when charging. Launch day iPhone 17 Pro 256GB, UK.
iPhone 17 Pro and Pro Max owners are having trouble with the speakers of their devices, and have complained about a static or hissing noise that occurs when the iPhone is charging.
There are multiple discussions about the issue on Reddit, the MacRumors forums, and Apple's Support Community, where affected users say there is a noticeable static noise "like an old radio." Some people report hearing it when playing audio and turning the volume down, while others say the static is audible without anything playing from the speakers. In some cases, there is a low crackle or a hiss when scrolling through webpages when the iPhone is charging, and some people hear the noise at low volumes even when the iPhone isn't on a charger.
Affected users report that the noise can be heard with chargers of all types, including Apple's official chargers. MagSafe charging causes the problem as well, but users report that the static noise is quieter. Unplugging the iPhone from the charger eliminates the sound for users who are experiencing the static noise when charging.
Some iPhone 17 Pro users have exchanged their devices for new ones, but have run into the same issue.
One Reddit user has been in contact with Apple support, and says the issue has been forwarded to Apple engineers. Apple is apparently working on a fix, but the iOS updates that have been released so far do not appear to solve the problem. The sound is subtle according to most reports, so it may be a widespread issue that only those sensitive to the noise have noticed.
Article Link: iPhone 17 Pro and Pro Max Users Report Static Speaker Noise While Charging
Soundgate17PM 512gb - also same problem while charging with multiple different cables. the sound doesn’t seem to be coming from the speaker but the actual charging port. goes away the moment you unplug the cable. and can worsen/gets louder while scrolling. it is very subtle though and only noticeable when scrolling on the phone in silence without sound.
Thanks for your careful scientific testing and description of the results. This is the approach that's needed to objectively diagnose issues like this.Detailed report: iPhone 17 PM Static/Buzzing Noise (Charging vs Unplugged) + Audio Proof
Hi everyone,
I’ve been owning an iPhone 17 Pro Max since late November (256GB, Silver, eSIM). I can confirm I am also experiencing these static noise issues (buzzing and sometimes high-pitched squealing/whining). I noticed it from day one, even before reading about this widespread issue online.
For reference, the noise is audible in a quiet environment and is roughly as loud as the system audio would be at "2 clicks" up from zero volume.
That being said, the system volume setting itself has no influence on the loudness of the static noise. It remains at a constant volume whether the phone is set to 0%, 50%, or 100% (provided there is no other louder audio playing to mask it).
Charging behavior:
I hear it very distinctly when the battery is charging (usually limited to 80%). I want to clarify that I exclusively use high-quality chargers: Anker Prime Charger 250W + Anker cable, or the official Apple brick and cable.
Triggers:
The static is audible in many situations when the phone is under load:
It doesn't seem linked to network features (Cellular, WiFi, BT) as the static persists and sounds identical even in Airplane Mode.
- Waking the screen for 1-2 seconds.
- Simply scrolling through Home Screen pages.
- Most virulent scenario: Doom-scrolling on Reddit for a few seconds.
- Worst case: Opening a video on Reddit in Mute mode and scrubbing the timeline/slider back and forth (see my audio files below).
Source of the noise:
To corroborate other reports: the signal comes mainly from the bottom-left speaker area. If I cover it with my finger, the noise becomes almost inaudible. I say "almost" because the top earpiece speaker seems to emit the noise as well, though it sounds more subtle and less aggressive there.
Unplugged behavior:
Beyond charging tests, I also tested the device while running on battery. To my surprise, the static does not disappear completely. It is present but at a much lower level that I hadn't consciously noticed before. But it definitely exists in both scenarios.
Audio Proof / Replication:
I recorded this using the Apple Voice Memos app while scrolling Reddit and scrubbing muted videos. Listening to these recordings at max volume undeniably confirms the presence and nature of the electrical interference.
File 1: Phone charging (80%), Reddit navigation:
Vocaroo | Online voice recorder
Vocaroo is a quick and easy way to share voice messages over the interwebs.voca.ro
File 2: Phone unplugged at the beginning of the audio, Reddit navigation:
Hoping this helps advance the understanding of the problem. Thanks for reading.
Did you send this to Apple Feedback?Thanks for your reply.
I have conducted a few more tests since my initial report, specifically using a USB-A to USB-C cable. Unfortunately, the result is identical to the USB-C to USB-C setup: the noise is still present and loud.
I don’t have a MagSafe charger to test, but it is possible (as some sources suggest) that the static is quieter or even inaudible with that charging method.
I also want to correct a vague point in my initial report: the static seems to come exclusively from the bottom speaker (left side, since the right side is the microphone), and not from the top earpiece.
I also want to clarify (answering some other comments) that this is not noise leaking directly from the USB-C port components (coil whine). If I carefully cover the speaker grille (and only the grille) with my finger, the static becomes practically inaudible. So it is definitely being driven through the speaker driver.
I’ve also refined my observations by testing new apps. For instance, with SoundCloud, swiping between songs triggers very high-pitched sounds (squealing/whining) while tracks are loading.
It is audible to the point where, even at 4-5 volume clicks, I can hear it over the music as the track starts. It is particularly irritating when listening to music at low volume, like in a quiet room at night.
Finally, the Anker App is also particularly aggressive, producing loud static at regular intervals.
New Audio Proof (Comparison)
I recorded 2 new unaltered clips using Voice Memos. Listen at max volume to hear the difference.
Trend: Noise intensity is High/Irritating (USB-C & USB-A) >> Low (Unplugged)
File 1: USB-C to USB-C Charging (80% battery) using Anker Prime Charger 250W + Anker cable
(results are identical with a USB-A cable or the official Apple charger + Apple cable):
File 2: Unplugged (Running on Battery, 80% charge):
Test Conditions (Triggers)
In the audio files above, I performed the following actions which reliably trigger the interference:
(Apologies for the background airplane noise in the recordings).
- Reddit App: Mute-scrubbing videos (classic trigger).
- App Store: Scrolling the "Arcade - All Games" tab (triggering auto-play videos).
- SoundCloud: Swiping between songs while paused. This specifically triggers the high-pitched squealing/whining.
- Anker App: Produces aggressive, rhythmic static interference.
Thanks again for reading.
I am also positive that the people who say that don't have it, do have the crackling noise.I’d like to add that my contribution alone is unfortunately not enough.
What is sorely missing is data from those who claim (sometimes quite vehemently) to not have this issue. I am willing to believe them in good faith, but it is frustrating that they don't seem willing to provide actual proof.
It would take less than 5 minutes to record a 1-2 minute Voice Memo in a quiet room while charging and scrolling through apps (like Reddit), then upload the .m4a file to a site like Vocaroo and post it here.
This simple act would allow those of us suffering from this static to know if "clean" batches actually exist, and help us decide if we should push for replacements with Apple. But apparently, 5 minutes is too much to ask.
So much for Internet solidarity in 2026...
No.Did you send this to Apple Feedback?
The same on the 14 pro and max. Maybe slightly not as loud.Anker doesn't change anything, so that's not it.
Exactly the same? A buzzing sound, sometimes like a burning candle? I was moving from a 14 Pro Max, but fortunately, I didn't have anything like that.
I wouldn't want to wonder what's normal, but rather have this information directly from Apple. Meanwhile, my support ticket died. What surprised me most was that after the technician took the phone, Apple Support refused to provide any details about the causes of the reported issues in this particular device.
For now, they seem to prefer to keep replacing people's phones, even though it doesn't change anything.
You probably do have it but it’s not something u can hear out loud I have exchanged 4 17 pro max and all 4 had it including the one I have now.Odd, don’t have this issue at all.
