nataly44
4
when i was travel with a gps app running for 30 minutes or more
my iphone got too hot and then i got a message
iphone needs to cool down before you can use it
can you please answer my 3 questions
1-does that did any damage to my iphone?
2-does that message normal when using the gps for 30 minutes or more
3-how to fix that
i have iphone 4s (new) in use for3 months only
running ios 5.0.1
and jailbroken
yes
it was under my windshield
with a case on the iphone
and i thing it was a hot weather
i was driving
also like i said its a new iphone 4s
It's probably not "normal", but was it sitting in the sun under your windshield or something? Just thought I would ask since you said you were using gps.
yes
A patient goes to see a doctor and complains that “Doc it hurts when I do this. Please help!” To which the doctor replies somewhat simply, “Then stop doing that”!
last question please im too worry
any damage happened to the iphone?
how can i khnow?
please answer me?
also its working good now with no proplems
how can i do if any damage happened to the iphone
My Iphone gets hot if i use it for more than a few minutes on 3G, i gave up caring a long time ago. :rolleyes:
As long as you let it cool down, and it's working fine now, then there probably isn't any damage. It likely wasn't the GPS that caused the problem, but the combination of it sitting in direct sun, under a glass windshield, inside a hot car. Any piece of electronics in that situation has a high likelihood of overheating.
Wait a sec, do you actually get a message that pops up on your screen if your iPhone 4s is too hot? I've never heard of this before.
I call baloney on that one too. Never in my entire life have I seen anything like that. And I have used iOS devices for a long time
I've gotten that same message a few times during the winter when the heater would blow on my iPhone. You can't do a thing with the phone while that message is displayed until it cools down.
Yup, it happens. There's an alert noise (it sounded like metal doors slamming) and the message pops up. When it happened, it scared the hell out of me, but I just let the phone cool down and everything has been fine since.
Much like the OP, without thinking, I was using it as a GPS (Waze) up on the dash.
That means nothing. "Having used iOS devices for a long time" doesn't mean that you've used them in situations where they would have overheated. Time and heat are two different things.
Search is your friend. Never assume that what you've experienced is all that exists.
http://support.apple.com/kb/HT2101
A lot of smartphones do warm up with GPS usage. The other conditions above certainly do not help.
"Some conditions and activities that may activate the Temperature warning message:
Leaving the device in a car on a hot day.
Leaving it in direct sunlight for extended amounts of time.
Using certain features in hot conditions or direct sunlight for long periods of time, such as GPS tracking in a car on a sunny day or listening to music while in direct sunlight."
There you go :eek:)
It made a lot of news when people first tried out their new iPads sunning themselves by a pool, and found out the tablets got too hot.
The iPhone version looks like this:
Apple is infamous for always trying to get by with the slimmest cases with no cooling. It's mostly a Jobs thing; he didn't like fans or cooling slots.
this is not an informative post so please do not treat it as such....
to OP:
you are definitely Blonde....hehe
or i'd like to think soooo
btw avoid keeping iDevices in the heat. as many pointed out the auto temp sensor kicks in and once it does, it will many times even when it isn't remotely hot. my expeience.
