Hello,
How are you?
I have a question.
I have a 17 inch Macbook Pro with a 9c99 display.
I do photo work with Photoshop and lightroom.
My display already has the 1920x1200 resolution.
So my question is if it is worth buying a LED Cinema Display 24 for it's IPS panel. The screen would be bigger, but the resolution would be the same.
So, is it worth the 600 Euros for the IPS panel, versus the TN panel I have on the macbook? Will the quality and color reproduction be really that different?
Thank you.
Best regards!
How are you?
I have a question.
Thank you.
Best regards!
