I have case open and working with the Senior Engineers about the Wifi and LTE issues.
There is a clear problem with the XS and XR phones using the Intel modems. We do not have an X for testing but Internet users seem to have similar problems. These phones perform exponentially worse as you move further from the Wifi source compared to previous iPhones and Android phones.
We have tested on multiple Wifi networks TWO iPhone XS Max's, OnePlus 6T, Note 9, iPad Pro 2017, TWO iPhone 8 Plus's.
In EVERY test, the XS's perform nearly half the speed as EVERY OTHER DEVICE!
Here are some results averaged from one test location:
OnePlus 6T - 105mbps down - 28mbps up
Note 9 - 103mbps down - 26mbps up
iPhone 8 Plus - 110mbps down - 27mbps up
iPhone XS Mx - 48mbps down - 10mbps up
If we test in the same room as the Wifi source, all devices do 300mbps down and 30mbps up.
The iPhone XS Max's were restored to Factory Defaults and running absolutely no apps that could degrade performance. We have been using SpeedTest by Ookla using the same test servers.
When we called Apple and provided our results, we asked if there were known issues. They had said they had calls on this and one person said they were aware of complaints online. In a very Politicially Correct way they said, "Cleary your test results show there is an issue with devices using the Intel modems."
We have tested these scenarios on iOS 12, 12.1, and 12.1.1 and all have the same results.
We are also seeing Wifi calling issues with the Phone XS Max's. It looks like the modem actually disappears as a device because the Wifi and LTE bars disappear in the upper right areas for a split second. This is when the Wifi call is dropped.
We are also seeing Wireless CarPlay lagging or locking as well. We have two iPhone XS Max's and two 2018 BMW X5's.
It looks like Apple is in SERIOUS trouble with these latest devices baed on Intel modems.
Although we are working with engineers on the issues, we asked about returns as we are past the 30 days. I was told that it would probably NOT be an issue based on the tickets, testing and results we are seeing.
This could and probably should lead to a class action lawsuit if they can't find software fixes for these devices.
Hoping for something positive from Apple.
