I bought the top of the line Macbook Pro and had to send the first one back, because the battery only lasted for about 2 hours.
The new one lasts for about max. 6 hours if I only surf the web, have brightness at 50% and only use the internal graphics card (thx to gfxcardstatus).
I know this should be about 8 hours and not 6, would you guys exchange it again or will the new one have the same battery range as well anyway.
don't really know what to do, don't want to keep exchanging, but on the other hand I paid 3000 euros for this machine and it should work as expected?
thanks for your advice
