MacBook Pro 2010 hard drive not recognised after battery was replaced, worked for one boot and then had a box with a question mark in it just wondered if resetting the PRAM would resolve the issue.
You might want to use the opportunity to add an SSD while you are there as well, if you haven't already, they make the 2010 an almost modern computer And a 6 year old HDD Is just waiting to fail.
Thanks for the advice however now I have the new cable my mac will not load the fans don't load up tried resting smc but nothing any advice as it does load when the cable is not in
Thanks
