I know this is a very common question but i couldn't find a solution in other threads. I have a Macbook Pro A1286 with the internal battery and about a month ago my little cousin spilled water on it. It stop working but i recently disassembled it, since it had no warranty after the spill, cleaned up the keyboard and the logic board and it started up. Everything works perfectly except from the battery. I doesn't work at all without the power cable on and the led light is always green. In the status bar there is a message saying (Not Charging) and the condition of the battery says Replace Now.
In the system profiler i get this info:
Battery Information:
Model Information:
Serial Number: W0942AZF977VC
Manufacturer: SMP
Device name: bq20z451
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 0003
Hardware Revision: 0003
Cell Revision: 0100
Charge Information:
Charge remaining (mAh): 0
Fully charged: No
Charging: No
Full charge capacity (mAh): 0
Health Information:
Cycle count: 117
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 12264
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
GPUSwitch: 2
Battery Power:
Display Sleep Timer (Minutes): 2
GPUSwitch: 2
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 85
Revision: 0x0000
Family: 0x00ba
Serial Number: 0x009d85a4
Charging: No
My question is... Is it just the battery and i only have to buy a new one? Is it the magsafe adaptor, the DC board or the logic board?
I tried a lot of tricks but if you can help plz reply.
Thanks a lot and sorry for the usual Thread.
Model Information:
Manufacturer: SMP
Pack Lot Code: 0000
PCB Lot Code: 0000
Cell Revision: 0100
Charge Information:
Fully charged: No
Charging: No
Health Information:
Cycle count: 117
Amperage (mA): 0
Voltage (mV): 12264
AC Power:
Wake On LAN: Yes
GPUSwitch: 2
Battery Power:
GPUSwitch: 2
UPS Installed: No
Connected: Yes
Wattage (W): 85
Revision: 0x0000
Family: 0x00ba
Charging: No
