Hello,
I got this issue, that is really annoying. Two weeks ago i bought a TimeCapsule (2GB). I've set it up and everything works like a charm.... EXCEPT the download speed on my 2 macbook pros. Using the same settings on speedtest.net (prefered server, etc) on all devices, i get the following results:
Iphone 6 (2 of them) and Ipad Air 2:
Ping: 6
Download: 24000 kB/s
Upload: 22000 kB/s
Macbook Pro 13" early 2011 and Macbook Pro 13" early 2015:
Ping: 6
Download: 16000 kB/s
Upload: 15000 kB/s
Every test that i have ran i made sure that that device is alone in the network. After a couple of tests i joined all the devices to the network, but there was no change in results.
My WiFi is set up as a 5Ghz one. Right now, the channels for the 2.4GHz and 5GHz are automatic. The distance to the time capsule is about 2 meters and it is in line of sight.
On both my laptops i checked (using alt+click on wifi) the signal and noise and they were both in order.
The early 2011 MBP was connected at 450 Mbps
The early 2015 MBP was connected at 975 Mbps
I've tried all the channels for the 5GHz network, same results
I tried to rule out speedtest.net (because of flash and OSX), but even on torrents i am still not able to get more than 16 MB/s
Then, i connected the ethernet cable to the 2011 MBP and i was able to get 23MB/s... so the actual connection is ruled out.
Same speeds (and the same differences) i get when the TimeCapsule is set up as Automatic (no separate 5GHz network).
However, what i noticed was that i can actually write on the Time Capsule's HDD with 35+ MB/s.
Maybe you guys know something i don't or that i didn't think of. I can't understand why on iphones and ipad i can get 20+ MB/s and on MBPs (even on the 2015 one) i can't get past 15MB/s over WiFi.
Thanks in advance,
/R
Ping: 6
Upload: 22000 kB/s
Ping: 6
Upload: 15000 kB/s
Thanks in advance,
/R
