I noticed today that the little indicator LED on my MagSafe cord is extremely dim. Its not visible in direct light and is only barely visible in complete darkness. I checked the connection both my MBP and the wall and it appears there both fine. My battery indicator is showing the little plug symbol and says its running off the power adapter so it appears functional.
Just concerned because I've read similar stories where the MagSafe cord suddenly stops working all together. Mines about 2 years old so is it more likely just normal wear and tear?
Also any way to fix it would be nice so I can glance at it and tell if its working or not. 🙂
EDIT:
I tried cleaning the connector on the magsafe cord and the one on my MBP with a q-tip dipped in 99% alcohol and it appeared to work for a moment but then it went dim again. And now when it goes dim it stops charging my MBP 🙁 Do I need a new MagSafe cord or could there be a problem with my MBP's logic board??
I cant afford to replace my MBP right now 🙁
EDIT:
