Hi everyone. I have checked MRoogle with no luck and I really really hope you can help me out with my battery issue.
The title says it all, basically my MBP's battery drains even if the computer is plugged. When I sat at my desk to use my MBP earlier today I noticed the battery was charging. That seemed very weired, I was sure it was at 98% last night. I decided to switch my computer off and let it charge all the way up.
When I turnt on my computer again i checked the battery and everything seemed normal, but after half an hour or so I noticed that my battery status icon had chaged from charged to not charging.
I loaded up Coconut battery and the battery was slightly over 90%...and it's still draining out while tipyng...
The AC socket is fine and I have an HDTV connected to the same power source. Needless to say the tv is working normally...
Any advice? I do not have an Apple shop nearby, the closest is over 200 km (approximately 140 miles) away.
Cheers from Italy...
EDIT: I have reset the SMC with no luck.
