worls747
2
HI, Since upgraded to 10.7.2. My Macbook Pro (Mid 2010) got weird...
when I'm only running 1 app at a time. (like Safari or Mail app). First 10 mintiues the fan RPM is 2000. and after 15 mins later it increase up to 6000 RPM. I do not know why!!! T_T
I'm not even running heavy application. It repast over and over again!.
this is really frustrating.. very loud...
So can anyone help me why my macbook fan runs up to 6000RPM randomly.. and back to 2000RPM and after 10 mins later 6000RPM -> 2000RPM -> 6000 RPM. (repeats)..
It happened since upgraded to 10.7.2 Lion. I Just clean installed Lion but problem still stands..
Have you tried an SMC reset yet?
Intel-based Macs: Resetting the System Management Controller (SMC)
______________________________________________________
Have a look at Activity Monitor (Applications / Utilities /) and select All Processes and sort by CPU to see what the culprit may be.
Also check the "System Memory" tab to see what your "Page ins:", "Page outs:" and "Swap used:" are.
image below uses sorting by CPU as an example
Further reading:
______________________________________________________​
Cpu
Further reading:
I checked. MY CPUS Are fine.. the highest one is under 10 % ..
I tried to reset my SMC but I followed how to do it step by step but maybe I'm doing wrong way. not working.
can you please tell me how to reset SMC on Macbook PRO (2010 MID)
- I turn off the macbook and connect it to mag safe adaptor. pressing option+control + shift + power button at the same time.
but it's seem doing nothing. :( please help
I would also try running the Apple Diagnostics (Hardware Test) to make sure none of the temperature sensors are bad
Goodness, I had this problem not too long ago. Mine had a faulty sensor, that could be you're problem. Hopefully you're MBP is still under warranty so you can get that fixed (Apple will have to replace the Logic Board; it's pretty expensive). To find out if this is your problem; do a Apple Hardware Test. That will tell you if there is a problem with your mac. Hope this helps.
