MacRumors
macrumors bot
70,498
42,196
Apple accessory maker Mophie today debuted a three-in-one portable battery pack, wall charger, and wireless charging pad.
The new Powerstation Hub is equipped with a 6,100mAh battery, one 5W USB-A port, one 15W USB-A port, one 18W USB-C Power Delivery port, and a Qi-enabled 5W wireless charging surface. The USB-C port can be used to recharge both the portable battery itself and connected devices like an iPhone or iPad.
The hub features foldable wall prongs, LEDs that indicate battery level and charging status, and a rubberized, non-slip finish. A 1.5-meter AC power cable and a 0.5-meter USB-A to USB-C cable are included in the box.
The new Powerstation Hub is available now on Mophie.com for $99.95.
Note: MacRumors is an affiliate partner with Mophie. When you click a link and make a purchase, we may receive a small payment, which helps us keep the site running.
Article Link: Mophie Debuts 3-in-1 Powerstation Hub With 6,100mAh Battery, USB-C and USB-A Ports, and Qi Wireless Charging
Mophie website is flagged as not secure, and images are not correctly sized. Doesn’t give me much confidence about the longevity of this company.
Not dissing wireless charging entirely but charging an iPhoneXR with my MBP USB charger is super fast and makes wireless charging such a chore. I have a 5/7.5/10W wireless charging pad but it sits unused because it's so slow. One of the reasons I decided not to go for Air Pods with the wireless charging case - kinda pointless.
Reactions: jagolden
I use a fast charger at work but use wireless charging exclusively at home. I’ve placed a charging pad in every room as well as any place you can sit. If you are charging from low battery wireless can be slow but at home I always have my phone on a charger when I set it down
This is a perfect desk-top application. I can see myself using this, especially for multi-device charging without all my devices being charged separately elsewhere.
Love my fast chargers. I have a few of them. 30W and 18W.
Reactions: jagolden
Next version: Drop the battery, make it less bulky, add another USB-C and USB-A, upgrade to 10W wireless charging. Perfection. I'll take two.
There is absolutely no reason for that to be that huge. It takes up BOTH wall outlets and ONLY has a 6100mAH battery? That's absurd, especially for the price. No way to justify carrying that around daily, or even for travel with it's size, wattage output and the price.
Reactions: mrz_V1
They are just fine.
I’ve been purchasing Mophie products since they pioneered the juice pack for the iPhone 4 and they’ve grown by leaps and bounds since then ( my iPhone XS Max I’m sending this from has the juice pack Access on it now. I wouldn’t worry about their longevity. They are rock solid just like their products.
Reactions: PC_tech
The one problem I see is the device has a wall prong, so either you use an extension cord or chose between wireless and regular charging but not both at once.
Laughably bad power capacity, I mean I could MAYBE justify the price if it was 15000mah but 6100mah is a joke, what is that gonna charge my phone once or twice maybe? For 100 bucks you should be getting 20000mah without question.
you do realize how huge/heavy one with 20,000 mAh would be right?
10k would have been nice, but this is bulky enough as is.
Also, I have about a dozen battery chargers and only one of them is 20,000 mAh. Most are in the 4-13k range.
Not sure exactly what your point is because this is a mammoth with only 6,100 mAh.
I’m afraid this is a toaster fridge situation. This thing is a wall charger doubling as a Power Bank, and I’m afraid that the heat from charging will damage the battery inside. Not to mention the small size of the battery inside.
In most of the time (except long travels) you don't need to bring the wall charger with you all the time.
The Mophie USB-C XXL is a 20000mAh battery and weighs 390g. Yes it's about 140g heavier but it provides 3 times the battery.
Reactions: jagolden and solace
see post below yours... it's not just a battery pack, thus it requires more circuitry/insides.
also, it's not THAT mammoth:
It's basically just a little longer than the 60 watt Apple charger
[doublepost=1561560935][/doublepost]
agreed.
I'd use this for business travel mostly, wouldn't be an every day carry battery for me.
[doublepost=1561561239][/doublepost]
this Anker one is $99 and is only 5000 mAh and has no wireless charging fwiw:
https://www.apple.com/shop/product/...n-power-delivery-battery-and-charger?fnode=85
trade off is it can charge USB-C laptops at 30W, but still not exactly cheap, especially for Anker who is known for much more affordable stuff than Mophie.
Reactions: haruhiko
I do like the competition between Anker and Mophie for a thing this size that is so versatile. But the price on these things are nuts. Someone do a teardown and show us it’s just two 18650 cells in these things. In which case it’s cheaper to just tape a wireless charger to a $15 battery pack.
Apart from wireless function is this any real difference?
DoSHIn USB C Portable Charger 10000mAh Wireless Power Bank QC3.0 Input and Output Power Delivery Power Bank with Interchangeable Wall Charger for MacBook, Nintendo Switch, iPhone, Samsung and More https://www.amazon.co.uk/dp/B07PBYC5V6/ref=cm_sw_r_cp_api_i_wJjfDbTGVBKRX
I like mophie, and Anker but the price is very high when compared to this. Be handy for travels.
I have the Apple 18W USB-C charger now and for UK it has foldable prongs, so welcome! I've changed all my cables now to USB-C for iPhone and others, just need a watch USB-C so not sure I need this
