3goldens
macrumors 68000
Another thing to add to my electric bill….think I will pass.
That commenter didn't understand your post. He is saying you can stack them (in a vertical stack), while still HORIZONTALLY oriented. i.e. - he didn't get it.The illumination is from the intended top side though, right? So it would be lit up from the left/right as opposed to from above (or below)?
Interesting that there isn't a vertically oriented option. If there was, I'd be interested.
So basically 3k for a set of bland IKEA-looking boxes - amazing. Not to mention that virtually no one lives (or wants to live) in a place that looks like a Blade Runner-style neon bar.It’s cool for a store… but I, for one, want to live in a house where my things are not so numerous or amassed that I would benefit from a wall of displays.
There are cool ideas for lighting out there, but less is more when it comes to “things”.
[..edit..]
And that wall of 54 boxes costs over $3,640 USD… the things “in” the boxes aren’t worth half that much in the aggregate.
MR needs to clickbait sometimes to help keep the lights on...This is a very well-written article, & you've obviously put a lot of thought & effort into this.
But with all due respect,
What do $60 plastic trophy cases have to do with Apple, or even tech news?
Perhaps this would be a more appropriate post in one of the forums?
Ummm because people like and buy their products maybe?Really wondering how they stay in business.
YouTubers with enough followers plus what has got to be massive markup: $68 each (for the first 4, then $63 after) for a $5 storage box with built in LED strips with modular connectivity.Really wondering how they stay in business.
Now I am wondering about this peopleUmmm because people like and buy their products maybe?
Do people really spend their hard earned money on this ****?!
If you have a collection that you want to show off, whether it's high-end sneakers, expensive collectible vinyl figures, or something else you want to draw attention to, Nanoleaf's EXPO Smart LED Display Cases are worth checking out. They're priced at $270 for a pack of four, with additional expansion cases available for $63.
The EXPO Smart Cases are LED equipped display boxes for collectibles. They're rectangular, with white plastic sides and clear plastic at the front and the back. The front panel opens up so that items can be placed inside.
In terms of size and shape, they remind me of the shoe boxes that people get to store their sneakers. They're just under 15 inches long, 11.4 inches deep, and 8.7 inches tall. The inside measurements are a bit smaller, so you have about 7.5 inches in height. The height has been the most limiting factor in my testing, since taller collectible items won't fit inside. For shoes, which these cases are definitely designed for, you can fit up to a size 15 sneaker. Nanoleaf has a guide on what other kinds of things fit inside, but there isn't a mention of a weight limit. Most collectibles that will fit aren't wildly heavy, and the cases are sturdy, so weight probably won't be a concern for most people.
These ship in flat-packed, and each box has to be assembled one-by-one. The pieces only go together one way and it's not terribly hard to get them put together, but it did take me a good half hour to set up four of them. I found setting them up to be somewhat frustrating because it takes more force than you might think to get them to snap in place.
Once assembled, they feel sturdy, even though they're made of plastic. They don't look or feel cheap, but it is clear that they're plastic and not another material. Nanoleaf only makes the EXPO Cases in white, and that isn't going to fit some aesthetics. I suspect there are a lot of collectors who might prefer black, but the white does work well for highlighting the items inside. Either way, the assembly keeps what's inside dust free, but Nanoleaf doesn't mention UV protection so I assume that's not included.
Like Nanoleaf's lighting panels, the EXPO Cases link together with connectors, which are included in the box. There's a main controller box that provides power and that the power adapter plugs into, and the rest of the boxes plug into it. Nanoleaf designed them to be set up all in one row or stacked up, so you can actually make several different designs. There isn't any wall mounting hardware, so they're designed more to go on the floor or on a surface like a desk or a shelf.
The controller box has a set of touch-based controls on it for changing the colors and the brightness without the app, and I hate them. They use touch activation instead of physical buttons. The buttons are too sensitive, and if you even brush them, they activate. They're also somewhat annoying for actions like resetting the EXPO Cases. I would have preferred standard physical buttons.
I set the cases up across a set of bookcases in my office in a horizontal line, but I also tested them in a two row vertical orientation, and they stack well. There's an indentation at the top of each box that the base of a second box sits in for a secure fit, but there's no clip or other mechanism that holds them in place other than surface area and the indentations. I wanted to be able to put LEGO that I have on top of the cases, but the depressions would have made for an unstable surface, which is something to keep in mind if you want to have something on top. I added some craft foam to have a flat surface, and that ended up working well.
I have seven cases to fit across my bookcase, but up to 300 can be connected together. Once you have over eight cases, you need a 75W power supply unit from Nanoleaf, which I believe is sold separately because the base kits ship with a 42W power supply. A 75W power supply supports 14 cases, so if you go over that number, you'll need two or more power supplies. Note that while 300 can be connected, Nanoleaf says you should only stack them 16 high vertically. There's no limitation in a horizontal orientation.
The EXPO Cases connect to the Nanoleaf app, and are HomeKit-enabled, so you can access them in the Home app and control them with Siri. Thread is included too, for improved connectivity. Like other Nanoleaf products, they can be set to over 16 million colors, with different patterns and light sequences that are available in the app. I like Nanoleaf's app, and I think the company has done a good job making it easy to get a whole range of different scenes and color options for its products with little effort.
You can set the EXPO Cases to solid colors or create your own animated scenes in the app, but there are also community created scenes and AI Magic Scenes. With community scenes, you can download a lot of really great color/pattern combos created by others, and the AI Magic Scene lets you put in any phrase to have AI come up with something. There's an option to create a playlist to have the EXPO Cases cycle through scenes, and there is a rhythm option, which allows the selected colors to shift in time with music that's playing. You can also connect them to a PC or Mac setup with other Nanoleaf lights u... Click here to read rest of article
Article Link: Nanoleaf EXPO Case Review: Fun LED Display Boxes for Sneakers and Collectibles
