iceman600
42
i have a WD external hard drive which i format to ntfs to use as a storage for my WDTVlive. i format it to NTFS so i can transfer large files (4GB above)
Problem is when i connect it to my macbook pro i cant write to it... it only set to read.
how can i set it to read and write on my macbook pro? thanks... :confused:
You need additional software to write to a NTFS partition in OS X. Google is your friend. :)
I've heard reports of paragon and macfuse being quirky at best, use at your own risk if you do.
