waterlover123
Hi,
I have a problem with Optimized Battery Charging feature.
My Mac is connected to a charger most of the time and it always have "Charging on hold" and says "Rarely Used On Battery" then it starts to drain the battery to 95% or so, then it starts charging again and as soon as it reaches 100% it says again "Charging on hold" and "Rarely Used On Battery" and the same thing happens again and again.
It’s M1 Air and I'm using the original 30W charger, I was suspecting that it might not be enough for keeping the laptop charged and powering it at peak, but I tried a third-party 65W charger and the same issue happened! Any ideas how to solve this?
You can manage your "optimized battery charging" using AlDente. Install AlDente and turn off Apple's optimized battery charging.
I know about this app, but I prefer to not use a third party app, I wish I can make the built-in feature to work as intended
Do any one knows how to reset the data of optimized battery charging feature?
AlDente works much better than Apple's crappy battery management. I have used it for over 5 years now on multiple Macs and it never fails. All Apple has to do is give Mac users a customizable set charging limit... but if they do, it will likely only be for M5 + Macs for greed.
