superczar
8
Would really appreciate if some of the new Alu (or old) Macbook owners can post their power draw readings while running on battery
Mine reads:
Display (dimmest) with wifi on: -744 mA
Display (medium) with wifi on: - 789mA
Display Max with wifi On : - 919mA
Full set of readings:
Model Information:
Serial Number: SMP-bq20z951-3932-794
Manufacturer: SMP
Device name: bq20z951
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 002a
Hardware Revision: 000a
Cell Revision: 0100
Charge Information:
Charge remaining (mAh): 2851
Fully charged: No
Charging: No
Full charge capacity (mAh): 4077
Health Information:
Cycle count: 7
Condition: Good
Battery Installed: Yes
Amperage (mA): -769
Voltage (mV): 11673
Here is how to get these readings:
Open System Profiler>Power
You need to refresh the readings (Command-R) a few seconds after changing the brightness (or any other setting that would change the power draw)
Reason why I am acting so fussy about these readings is here:
https://forums.macrumors.com/threads/599506/
Now I am trying to assess if the notebook is able to manage the power draw efficiently while running on batteries
I am in India while this notebook was bought in the US..
Now even though the notebook is eligible for a DOA, the process is going to be a bit convoluted because it is an international DOA and seems like it may take upto 2-4 weeks :(
Wow, maybe that's why my battery life sucks. -1352... screen at max, WiFi on, Bluetooth off, IR remote off, currently running Safari, Mail, and AOL (older version).
Hmm now I am worried mine says
Amperage (mA): -923
at lowest display brightness and wifi on, Bluetooth off
For me it's impossible to get under 1200 even with the lowest settings, normally it displays 1500... In that case the problem is the battery or something else?
It varies with what kind of macbook you have. The older CCFL panels use more power than the newer LED backlit models. Some HD's use more power than others to keep spinning. Some WiFi networks will sap more power than others depending on signal strength.
I have a new macbook alu, i am sitting 20 centimeters next to the wireless router:) And my macbook lasts at most 3.5 hours. Even though the capacity is 4120...
You also use less mA if you run when you're not plugged in and all the energy saving options are activated. Having Firefox or Safari or any other apps will use a lot more energy, by the way. Photoshop or any pro tool eat a lot of energy, even if they're idling.
If you're sitting so close to the router you might be able to find an outlet, so you can just plug your laptop in :D
No but seriously, if you're doing intensive stuff 3.5h is not that bad... If you're just browsing and have like 2 tabs open (not youtube or anything intensive) then you need to calibrate your batt or get a new one...
also, the amount of memory, type of video card and cpu all matter.
people should be giving a full spec list and have the same os/programs running.
ie: max brightness, wifi on, bt off, ir off and no accessories attached with laptop not plugged in.
cpu:
memory:
hdd:
video card:
battery cycles:
