Status
Sure! I use this:
pmset -g log|grep -e " Sleep " -e " Wake "
Thanks!
I found this upon googling, and the output seems different than what I saw in this thread. (I only grep'd " Wake " but still got a load of stuff.
I'll try it again. I also dumped the output to a text file.
Regards,
R
Reactions: raghiid
I found this on my MacBook machines. The way I found to resolve it without having to make changes was to logout before closing the lid to sleep the machine. May not be appropriate for everyone, but easy to implement 🙂
I've improved my battery usage when slept, but do still see some really weird "wakeups" in the middle of the night, ie after disconnecting from my dock and shutiting the lid last night it wakes at 8pm then again at 0345am
Code:
2023-11-14 18:02:09 +0000 Sleep                   Entering Sleep state due to 'Clamshell Sleep':TCPKeepAlive=disabled Using Batt (Charge:75%) 7224 secs
2023-11-14 18:02:11 +0000 Wake Requests           [*process=powerd request=CSPNEvaluation deltaSecs=7228 wakeAt=2023-11-14 20:02:39]
2023-11-14 18:02:11 +0000 PM Client Acks          Delays to Sleep notifications: [com.apple.bluetooth.sleep is slow(1817 ms)]
2023-11-14 20:02:33 +0000 Kernel Client Acks      Delays to Sleep notifications: [AppleH13CamIn driver is slow(msg: SetState to 1)(1006 ms)] [AppleH13CamIn driver is slow(msg: SetState to 0)(274 ms)] [heard timed out(30000 ms)] [AppleBCMWLANCore driver is slow(msg: SetState to 0)(134 ms)]
2023-11-14 20:02:33 +0000 Kernel Client Acks      Delays to Wake notifications: [RTBuddy(ANS2) driver is slow(msg: SetState to 2)(101 ms)] [AppleMultiFunctionManager driver is slow(msg: SetState to 1)(114 ms)] [AppleConvergedIPCOLYBTControl driver is slow(msg: SetState to 1)(113 ms)]
2023-11-14 20:02:39 +0000 Sleep                   Entering Sleep state due to 'Maintenance Sleep':TCPKeepAlive=disabled Using Batt (Charge:75%) 27850 secs
2023-11-14 20:02:41 +0000 Wake Requests           [*process=powerd request=CSPNEvaluation deltaSecs=27849 wakeAt=2023-11-15 03:46:50]
2023-11-14 20:02:41 +0000 PM Client Acks          Delays to Sleep notifications: [PLSleepWakeAgent is slow(672 ms)] [com.apple.bluetooth.sleep is slow(2014 ms)]
2023-11-15 03:46:49 +0000 Kernel Client Acks      Delays to Sleep notifications: [AppleH13CamIn driver is slow(msg: SetState to 1)(1006 ms)] [AppleH13CamIn driver is slow(msg: SetState to 0)(274 ms)] [heard timed out(30000 ms)] [AppleBCMWLANCore driver is slow(msg: SetState to 0)(134 ms)]
2023-11-15 03:46:49 +0000 Kernel Client Acks      Delays to Wake notifications: [RTBuddy(ANS2) driver is slow(msg: SetState to 2)(101 ms)] [AppleMultiFunctionManager driver is slow(msg: SetState to 1)(114 ms)] [AppleConvergedIPCOLYBTControl driver is slow(msg: SetState to 1)(113 ms)] [AppleBCMWLANCore driver is slow(msg: SetState to 0)(133 ms)] [RTBuddy(ANS2) driver is slow(msg: SetState to 2)(102 ms)] [AppleMultiFunctionManager driver is slow(msg: SetState to 1)(116 ms)] [AppleConvergedIPCOLYBTControl driver is slow(msg: SetState to 1)(115 ms)]
2023-11-15 03:46:56 +0000 Wake                    DarkWake to FullWake from Deep Idle [CDNVA] : due to Notification Using BATT (Charge:73%) 5 secs
2023-11-15 03:46:56 +0000 Kernel Client Acks      Delays to Sleep notifications: [AppleH13CamIn driver is slow(msg: SetState to 1)(1006 ms)] [AppleH13CamIn driver is slow(msg: SetState to 0)(274 ms)] [heard timed out(30000 ms)] [AppleBCMWLANCore driver is slow(msg: SetState to 0)(134 ms)]
2023-11-15 03:46:56 +0000 Kernel Client Acks      Delays to Wake notifications: [RTBuddy(ANS2) driver is slow(msg: SetState to 2)(101 ms)] [AppleMultiFunctionManager driver is slow(msg: SetState to 1)(114 ms)] [AppleConvergedIPCOLYBTControl driver is slow(msg: SetState to 1)(113 ms)] [AppleBCMWLANCore driver is slow(msg: SetState to 0)(133 ms)] [RTBuddy(ANS2) driver is slow(msg: SetState to 2)(102 ms)] [AppleMultiFunctionManager driver is slow(msg: SetState to 1)(116 ms)] [AppleConvergedIPCOLYBTControl driver is slow(msg: SetState to 1)(115 ms)]
Sleep/Wakes since boot:1288   Dark Wake Count in this sleep cycle:2
2023-11-15 03:47:01 +0000 Sleep                   Entering DarkWake state due to 'Clamshell Sleep':TCPKeepAlive=disabled Using Batt (Charge:73%)
2023-11-15 03:47:15 +0000 Sleep                   Entering Sleep state due to 'Clamshell Sleep':TCPKeepAlive=disabled Using Batt (Charge:73%) 7234 secs
2023-11-15 03:47:17 +0000 Wake Requests           [*process=powerd request=CSPNEvaluation deltaSecs=7232 wakeAt=2023-11-15 05:47:49]
I think that regardless of being in sleep mode your mac will sync with iCloud especially if there are two or more machines with the same iCloud account. So, although you may have only one machine it will still sync with the cloud while resting. Someone mentioned how logging off before sleeping helped. IMOO that should work.
Funny thing is these days after moving from an i5 MacBook Pro to m2 air, I feel my mac loses more battery charge while sleeping than when I’m using! I use it for hours at a stretch for various purpose and the rate of battery dip seems smaller compared to when in sleep mode.
Do you have MS Office installed ?
Yes. Though I dont have an active subscription. I installed it from App Store. Even though I don’t have an active subscription I can do all the work apart from syncing it to OneDrive. I can save the document to my mac, no auto save functionality thats all.
So without an active subscription does the notorious Microsoft background sync drain battery?
Wouldn’t it be the easiest solution to just shut the MacBook down at end of the day? No more bat drain, reduces energy consumption and probably even has psychological benefits (complete the day and start to relax).
It’s not the background sync, it’s the updater that checks for new version. Go to your Login items in Settings and disable it. That’s what caused the drain for me.
Reactions: rachislenska
