Hello. I have a first-gen white macbook, you know, the core duo ones.
The thing is that my audio port is stuck thinking it has connected a digital output and the red led is glowing all the time and I can't hear anything from speakers.
I've tried connecting and disconnecting several times a plug, also tried to insert different objects as mentioned in other threads to disable the microswitch, but I can't.
Is there a software fix for that? Can I disable the digital sound output so I can use my speakers?
I know the speakers work cause I can hear the chime everytime I turn it on.
Thanks a lot
Thanks a lot
