Hi there. I have a 15" MBP '10 (i5 2.4 Ghz)
I'm having troubles with my new WD Scorpio black 750 Gb.
After installing it, partitioning and formatting, I copied my old system Carbon Copy Cloner, booted and everything seemed fine.
But after a while, I'm getting disk corruption, every time with the same error:
This is right after I repaired the disk after booting with the OS X disk and running disk utility.
SMART status is OK, and I already ran a surface scan with techtools pro, no bad blocks found, so physically, the hard drive seems fine.
What should I do? Shouldn't OS X support advanced drive format (4k) drives? Is this because I'm cloning the disks? Should I make a clean install?
Help me please, I really am lost here.
