From MacRumors front page:Hi guys,
Is there any news about an integrated solution for connecting a PS3 to 24'' Led Display at a decent cost?
Thanks
Skorpien,
I'm sorry, but I don't think that will work. I think its the same as the Dr. Bott video link, that I had to return because it doesn't work to connect a PS3 to the 24'' Led Display. If I am not mistaken the product you showed only "supports" 1920x1200 resolutions, but it doesn't upscales from 1080p or 720p to that resolution. For that you will need an hdmi to MiniDisplay Port upscaler. If you look at the specifications of the Kanex Xd it only states that it "Covert PC DVI signal to DisplayPort format to Apple® LED Cinema Display 24" at 1920x1200", so I bet it doesn't upscales hdmi signals from 1080p to 1920x1200.
It only works fine on the 27'' iMac because its display supports 720p, therefore the Kanex XD only haves to convert the the input resolution (720p) signal to MiniDisplay Port. It doesn't need to upscale the input signal, as it would need in order to connect to an 24'' Led Display.
Does anybody corroborates this?
Thanks
Skorpien,
Thanks
You have received a message regarding your service request.
Yes, the Kanex XD is compatiable with both iMac 27" and Cinema Display 24" it upscales to 720p only. But has an output resolution of 1920x1200 for the Cinema Display only.
Kanex Team:
http://www.kanexlive.com
hey dude do you know the name of the device that mix the scaler and coverter? im interested
Seconded. OP mentioned this earlier, but I can't find any mention of such a product on the Atlona site.
That's because there is no such product!
Hey everybody,
I know for a while now a lot of people have been wanting a way to hook up the PS3 (or any other non-Mini DisplayPort device for that matter) to the LED Cinema Display. There is finally a way to do it now thanks to Atlona Technologies.
For any DVI-enabled Mac or PC all you will need is there new DVI to Mini DisplayPort Converter.
Now for the PS3 it is a little more complicated. You can't simply use just the DVI to Mini DP Converter, because the LED Cinema Display doesn't support any of the resolutions output by the PS3. So to fix this you need their HDMI Scaler.
I currently have both of these devices to use my PS3 with my LED Cinema Display and I am extremely pleased with the outcome. The picture quality is absolutely amazing. This is absolutely the best display to use with a PS3.
As of now using these two devices with the proper cables is the only solution for connecting a PS3 to the LED Cinema Display and getting a full 1080p picture.
Atlona says though that they will be releasing a new device which combines the functionality of these two devices into one and they estimate that it will cost $200-250 (It should be available by the end of the year). It will also allow you to keep your Mini DP enabled computer and HDMI enabled device plugged into the box simultaneously and will have a switch to allow you to choose which one is displayed on the screen.
Hope the quality of the pics is good enough...if not I will upload uncompressed version to flickr and post a link.
