Pugnax
5
Hey-- I'm just wondering if anybody knows whether it is possible to obtain a replacement battery and power supply for such an old computer. My 17-inch MacBook Pro is about five years old, and the battery seems to be completely dead. It will not start up, will not take a charge, and cannot be used, whether plugged in or not. A multitester test suggests that the power supply no longer works either.
My MacBook has one of the older-design power supplies, with the circular port, rather than the newer, magnetic, rectangular ones.
I'm planning on getting a new MacBook in the near future, but I need to access some things that are saved on my old Mac's hard drive, if at all possible...
Any help is appreciated!
If you have the old style chargers, I think you have a 17" Aluminum Powerbook, not a Macbook Pro. Ifixit.com has a guide to repair any replaceable part in that machine as well as an inventory of spare parts.
These are common aftermarket parts for most brands of laptop. I assume these are readily available for your MBP both from Apple and from other companies. You could check on Ebay but proceed at your own risk when dealing with non-Apple parts.
