FigmentNewtonII
My iMac G4 (15" 2003) has some parts in need of replacement. The most notable being the hard drive. Also the disk drive can no longer push the door out of the way without being assisted. I have an eMac (2005) downstairs that isn't being put to use and I already have one for myself in my room. I was wondering if I can remove the disk drive and hard drive in the eMac and place them in the iMac? Are all the connections the same or did Apple switch to anything different for the drives?
Both the hard drive and optical drive should both be IDE in the eMac and iMac, which means you can swap them and they'll work fine! Only the G5s were ever SATA.
Just make sure you set the eMac drives to be the same jumper setting as on the iMac drives.
i have imac 27 but lcd is damage , can i rebuild my imac on a mac chasis ???
any ideas ?
That is an Intel Mac. None of the parts would fit in any other Mac's chassis except maybe the hard drive and optical drive. Your best bet would be to get a replacement LCD. A custom case could be fabricated, however it would be expensive and more then likely not worth it because of heating issues.
