MacRumors
macrumors bot
70,083
41,606
Back in March, Hyper released its HyperJuice Magnetic Wireless Battery Pack for the iPhone 12 lineup, promising customers an easy way to wirelessly charge their devices on the go. At the time, there were relatively few options for portable MagSafe-compatible battery packs on the market. Now, though, thanks to Apple's recent release of its own MagSafe Battery Pack, there is a little more competition, and Hyper's battery pack stacks up as a worthy competitor.
Design
One of the most eye-catching aspects of the battery pack is its size. Like Apple's MagSafe Battery Pack, Hyper sells one battery pack for all iPhone 12 models, meaning the size must be unawkwardly big enough for the iPhone 12 Pro Max but remain small enough to fit on an iPhone 12 mini.
I used it with my iPhone 12 Pro Max, and I found it to be too bulky with its design, although as a disclaimer, I do have rather small hands. The battery pack has smooth, curved edges on either side, so it's relatively comfortable and natural to hold, but difficult to use your iPhone one-handed normally with it attached.
In practice, I found that the battery pack's design leads it to rotate ever so slightly if you're typing or on a phone call. It's definitely not a deal-breaker, and some blame can be put on Apple for the strength of the magnets. Overall, though, the battery pack stays firm and set in place in casual use.
If build quality is something you're concerned about, you shouldn't be. Hyper's battery pack is an excellently well-built product, made with hard plastic on the front and a softer cushion-like coating on the back. The finish on the back, which attaches to the iPhone, is highly welcomed as it not only protects the battery pack, but also the iPhone itself from any scratches or scuffs.
In my normal day-to-day use with it, it's held up very well and any scuffs that do appear can be easily cleaned away.
Functionality
Each person's use case for a battery pack will differ, but in my experience, attempting to use the battery pack while shopping or while out on a quick jog with it in my pocket proved to be a challenge. In other situations though, such as laying in bed without a wire nearby or at your desk, the battery pack can come in handy thanks to the ease of simply attaching it to the back of the iPhone without the hassle of wires.
Performance
On the performance side, the Hyper battery pack features a 5000mAh, 18Wh battery that provides power to Apple devices at 7.5W. You can use the pack as a standard portable power brick with a USB-C port that provides power at 12W, which can be convenient if you have a non-MagSafe device that needs a charge. That USB-C port on the battery pack can also be used to charge both the iPhone's battery and the pack itself at the same time when attached.
Hyper's battery pack has a 5000mAh, 18Wh battery, which given its size is impressive. Each person's direct experience with the battery pack in terms of how much it can charge their device will vary, depending on several factors.
With Hyper's battery pack, however, you should expect to get a sufficient charge. In my experience, with the phone left untouched, it gave me around 73% of a charge on an iPhone 12 Pro Max, and you'll obviously get a greater percentage of a refill on iPhones with smaller battery capacities.
There are four lights on the front of the battery pack, which are the only indicators of the battery pack's current status and charge. On the other hand, Apple's MagSafe Battery Pack allows users to see the battery pack's specific charge on iOS, a feature that third-party accessory makers cannot utilize currently.
The Bottom Line
The iPhone 12 is the first iPhone to bring Apple's MagSafe technology, which originated in a different form on the Mac, to the iPhone. MagSafe is the future of the iPhone, as Apple will likely eventually rely on it entirely for power with the rumored removal of the Lightning port within the next few years.
Having said that, MagSafe on the iPhone is still a fairly new technology, and the accessory industry that it has begun to create will only become more robust and diverse with options as the years go by.
Hyper's Magnetic Wireless Battery Pack does what it promises to do; it provides your iPhone 12 with a enough extra amount of juice to help you get through your day. Depending on your use case, it can be a great accessory for customers of the iPhone 12 lineup looking for an easy way to charge their iPhones on the go.
Everyone's lifestyle is different, and some may find that Hyper's offering fits even better into their daily routine than it did for me. Either way, for $39.99 and a 5000mAh battery, Hyper's Magnetic Wireless Battery Pack is a top-tier portable wireless charger, especially when Apple's offering is more than twice the price.
How To Buy
Hyper's Magnetic Wireless Battery Pack can be purchased on its website for $39.99.
Note: Hyper provided MacRumors with a HyperJuice Magnetic Wireless Battery Pack for the purpose of this review. No other compensation was received. MacRumors is an affiliate partner Hyper Shop. When you click a link and make a purchase, we may receive a small payment, which helps us keep the site running.
Article Link: Review: Hyper's $40 Magnetic Wireless Battery Pack Is a Worthy Competitor to Apple's MagSafe Battery Pack
Reactions: peanuts_of_pathos
Am I the only one who finds the form factor of the phone based magsafe to be awkward and suspects that Apple will come out with a magsafe 2 sooner than later to address that kind of problem?
I was at the airport a few days ago and looked at a few Morphie batteries just for the heck of it. 5,000 mAh for $39.99 (wired). Ouch.
My biggest concern with these batteries (in the article) - how hot do they get when you're charging both at the same time? 5,000 mAh after conversion is a lot of loss (even wired).
My wired Anker 18W 10,000 mAh batteries lose a LOT of output when charging at 18W vs slower speeds - they also get insanely hot to the point where I know I've lost some serious capacity due to this heat.
I recently took a work trip where I was flying all day (8am - 5:30pm) and ... my iPad, my iPhone, and my Watch all were 50-70%+ at the end of the day. This was the first trip I didn't bring a battery on. I think the days of travel batteries are behind me.
The biggest problem with these battery packs is you can’t charge them via MagSafe (except for Apple’s, which requires you attach it to the phone). I have MagSafe charging stands in my house and car and can’t juice up any of these battery packs without getting out a cord. Just when you thought cords were going away…
Bought this unit and it was DOA. Hyper demanded a VIDEO of the problem then made me pay for return shipping. They suck.
Reactions: danielsan26
I would say you're the only one or in the minority because if it was such a "problem" that it would be upgraded later Apple wouldn't have created this design in the first place.
Reactions: Shark5150
I bought a hyper 100W usb-c charger and it was DOA. I got a replacement and it was DOA. They must have no QC or something. Thank goodness I bought through B&H who have excellent customer service. DON'T GIVE THIS COMPANY YOUR DOLLARS YOU WILL REGRET IT.
Someone forgot about the hockey puck, I mean the Apple USB Mouse...
Then you didn't understand my post. My point was Apple does not manufacture batteries so until the proper external battery is made that offers that same capacity but is thin as a credit card this is the size of the external battery for now on. That's why Hyper's battery is the same size as Apple's. That mouse example is a poor example. 🙄
And none of the trolls will complain about its thickness.
The universe isnt sending their best when it comes to these MacRumors trolls.
“Uh, but, um , more, um, but, different, but Apple evil..um”
Does that matter? I bought the Apple battery, but in practice I am only goign to charge it through the phone if the phone is plugged in. Because draining the phone battery to charge the external battery defeats the purpose. Doesn’t matter to me whether the phone or the battery is plugged in…
Reactions: Maconplasma
Is it me or are these charging capabilities for such bulky devices strangely low? I’d expect something of that size to charge an iPhone 12 Pro Max around 1.5 times. These things are the same size if not bigger than the internal battery. I understand there’s efficiency loss from the fact its wireless, but they really should have strived to at least give a 12 Pro Max one full charge from zero, for the marketing even.
Reactions: KeithBN
Apple should have offered a REAL battery pack case for the iPhone 12/12 Pro like what they did for the iPhone 11.
I thought the same at first but I realized this pack "Should" work with the next-gen of iPhones as long as they support MagSafe. I have so many of the Apple Smart cases for my previous iPhones just sitting collecting dust since I upgrade my iPhone every year due to IUP, With that said I still see it have major flaws such as the slow and inefficient charging (This is just the way wireless charging works) and the pack just does not stay on the phone securely. If you pick up the phone the wrong way the pack will fly right off and will leave you juggling to catch your phone. Like someone else said I wish Apple would have just added the smart connectors to the iPhones, they can accept the power to charge and who knows what other possibilities you could do with that type of connector.
Agreed. I want wireless re charging for battery packs. None of the MagSafe ones offer this. Even apple needs a wire
Reactions: iterva and KeithBN
