hey,
i just bought a 1TB Seagate extreme. on the box it said it only supports PC and i actually had some trouble formatting it with Disk Utility.
Everywhere i've searched says to create (for a bootable backup) a Mac OS Extended (Journaled) GUID scheme.
the drive shows up fine both in Tiger (10.4.11) on the mini, and Leopard (10.5.6) on the MacBook via USB.
when you plug in via firewire (which is kinda the point) - the LED's don't come on (or even flash) but the disk still spins up.
i have done a power cycle, unplugged everything for 10 minutes, reset the PRAM, and trashed a few caches. and yes. i tried another Firewire cable AND i know the firewire port works.
before you reply, also note that i unplugged all the USB devices and tried both firewire ports on the hard drive about 100 times.
i have no way to test if Firewire works on the MacBook (with Leopard instead of Tiger) because i have no firewire port...
plugging in the USB cable for power doesn't do anything, and i can't switch from USB first, then to Firewire - it's almost like the data port doesn't switch (but LED's stay on)
is there anything else i can do to get it working?
i seriously have tried every way i know and done about 4 hours of researching.
the place i know i'll get my answer is MacRumors!
please help
please help
