Hi,
Last night while backing up my MBA using time machine, i forget it's doing that and just closed the lid and went to sleep.
On the morning, noticed that the sleep LED is off. I connected the charger and turn laptop on. Everything went smoothly except two things:
- The power/sleep LED is acting crazy, when the screen is on, the LED is off. When put to sleep, the LED functions properly (fading out). Also, when I first turn on the laptop, the LED is on, after that it goes off.
- Finder takes ages to boot, the MBA function normally (can run any app) except for the finder.
I tried the SMC reset thing (not sure if it actually reseted it as nothing happened).
It's clearly a software issue.
What to do next?
Thanks guys.
EDIT: Thats how the LED functions, isn't it? I forgot how it used to!
What to do next?
Thanks guys.
