abs9986
42
I recently updated my 2009 macbook alu (2.0ghz) to snow leopard. Everything seems to be working fine except the battery life now gets about 3 hours instead of 4 hours with everything being used max brightness etc... I suspect as others have posted that this is due to the heat issues. My laptop feels noticablly hotter and istat says the cpu gets to 65 celcius when I'm on safari. Under Leopard, it never broke 60. Are other people having heat and battery issues and if so has anyone found a fix yet for this.
Thanks,
Alex
I should also note that my fan speeds get to appx. 3000rpm...I had never seen it go higher than 2000rpm under SL.
Thanks,
Alex
No issues here. It may be a tid bit warmer, but that's hard to say, as I've been doing much more lately.
Battery life is exactly the same, 3.5 hrs
I am not sure whether it is istat or not, but every time I look, the fan seems to working at around 2,000 rpms no matter what the temps say.
I did a 'clean' install on a 15" MBP
I also notice loss of battery time. at first.
I had read where it might take a few shutdown/restarts for things to 'smooth out'.
Well on my first couple of reboots I had bad/incomplete shutdowns, and a 1 Hour LOSS of battery time.
After a couple more reboots the computer now shuts down promptly and completely.
So I came here researching the Battery Problem, went off and got my MBP and prepared to reset the SMC.
Lo and behold, before I reset the SMC I noticed the battery time is now what it should be.
My MBP is 'new', purchased 3 days before the last update where they stripped the MBP of is Express Card Slot. ( I was happy that I bought when I did! )
