There's nothing in this thread mentioning a Macbook Pro by the op.I'm still unclear as to why you want your audio to output through BOTH the headphone jack and USB. Why not just leave the output set to the headphone jack and be done with it?
Also, in your first post you're asking about a Mac mini. In your most recent post, you're talking about a MacBook Pro. I'm confused![]()
If you can't answer the question why even post?
I gave you a couple of reasons WHY the OP wanted to do what he wanted to do. So I at least offered one answer for the problem at hand. Could also be the TV doesn't have a headphone output - did you ever think about that? I may not have ALL the answers, but I at least gave one possible answer.Right you are, I took a reply from another user as being from the O.P. My mistake.
Do I really have to point out the irony here? I don't see any solutions coming from your post either. Anyhow, I'm trying to determine why the solution is needed in the first place. Sometimes it's just the easiest way of working out a problem; I'm trying to help obviously.
I tried the Aggregate Device solution. It seemed like it should work. I created an aggregate output that included both devices. However, it plays iTunes through the USB only and computer sounds through the headphone jack only. I don't see any way to mirror the outputs.I don't need to hear computer sounds through the TV but iTunes needs to output to both sources.
